Activity Forums Blackmagic Design BM Intensity Pro slows PC to a halt
  • BM Intensity Pro slows PC to a halt
    Posted by Charlie Smith on September 2, 2011 at 2:42 pm
    Hey guys. Just built a brand new PC and everything else has been great with it til I tried installing the drivers for the Intensity Pro. (tried installing drivers, then inserting the card, and visa versa). I’ve tried disabling the update checker from startup. I even tried all different versions (8.0.1, 8.5, etc). Nothing gives and it’s got me so frustrated I’m ready to send it back. Only reason I’m still trying is because I know several friends and acquaintances using it as well with great results.
    Specs:
    ASUS M4A89TD Pro/USB3 motherboard
    AMD Phenom II X6 1100T 3.3ghz CPU
    ASUS EAH6870 1GB video card
    16GB Crucial Ballistix memory
    (2) 1TB HDDs in RAID0
    ASUS wifi card
    Antec High Voltage gamer 750w PSU
    Samsung BD drive
    Sincerely hope Someone can help me resolve his ASAP. My stress levels can’t handle this.
    George Sey replied 14 years, 12 months ago 4 Members · 11 Replies
  • 11 Replies
  • Charlie Smith
    September 2, 2011 at 3:06 pm
    I have also tried the Intensity in different PCI-e slots, to no avail.
  • Scott Francis
    September 2, 2011 at 3:27 pm
    Have u tried different Pci-e slots? Give us an idea of the issue you are having, won’t recognize it, no video input…etc?
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Charlie Smith
    September 2, 2011 at 3:41 pm
    As stated in the reply, yes I’ve tried different PCI-e slots. And it literally comes to a halt. CPU usage jumps to 100%, and I cannot do anything. Most of the time it will eventually just freeze and crash. Any attempt to shut the computer down (if I can get that far without it crashing), and 9/10 it will hang at shutdown. It all resumes as soon as the computer starts again.
  • Scott Francis
    September 2, 2011 at 4:02 pm
    Sorry, I was posting, when you posted the second time, didn’t see the pci-e slot comment. Try removing everything that is not needed from the computer (wifi card, extra usb attachment, etc) and if you have more than 2 strips of memory cut that down to 2 strips. See if that makes a difference. Go as bareboned as possible and see if you can trouble shoot what it may be. I have to re-arrange my video card and my Intensity several different ways to get mine to work well. I am now running my video card in my second 16x slot and the blackmagic one up from that in a 1x and it is working fine…good luck and hope this may help!
    Scott Francis
  • Charlie Smith
    September 2, 2011 at 5:39 pm
    Switched my video card to the lower PCI-e x16 slot, and tried each of the other PCI-e slots with the capture card, with the wifi card out, and only 2 sticks of ram. Still the same issue.
  • Scott Francis
    September 2, 2011 at 5:59 pm
    at this point I would contact BM and see what they say….did you update the firmware too?
    Scott Francis
  • George Sey
    September 3, 2011 at 9:51 pm
    Try intel as AMD and Black Magic gives headaches, ASUS Intel works great with Intensity Pro.
  • Saur Dash
    September 3, 2011 at 10:14 pm
    I had the exact same problem with the Intensity Pro using an Asus Crosshair IV Formula with a Phenom II X6. I was never able to resolve it, tried the Intensity Shuttle too with an Asus Crosshair V Formula but that doesn’t work either.
  • Charlie Smith
    September 3, 2011 at 11:09 pm
    Thanks George.. But unless you have the money to pay for my switching to Intel mobo and processor, that isn’t exactly a viable option.
    How about any suggestions on HDMI capture cards that are compatible with AMD processors?
  • Charlie Smith
    September 3, 2011 at 11:16 pm
    Contacted BMD, and am shipping the card to them to diagnose. Either the card was bad upon arrival, or is incompatible. Told me they would give me the specs of each machine they test it on as well. Also, the motherboard drivers are up to date.
