Activity › Forums › Blackmagic Design › BM Intensity capture
Posted by Joedully on January 19, 2007 at 2:55 amHi, I just received my new Intensity card and I am very excited to try it out… but, I want to use this card in a PC that simply captures a 720p stream. I do not want to load FCP or AP. Is there a utility that will simply allow for uncompressed capture and playback?
Gerard Weemhoff replied 17 years, 9 months ago 4 Members · 7 Replies -
Ryan Stone
January 26, 2007 at 4:04 amYeah, I bought one. I haven’t had a chance to pull footage directly from an HDMI camera, so I purchased the Gefen Component/Audio to HDMI converter.
Now I
Joedully
January 26, 2007 at 9:15 amI haven’t set it up yet as I am waiting on a new quad motherboard. I have a Sony HC3 to test with and I will post the results when I do. Thanks for posting… I think this card may have a place in producing part of a full length feature if it is stable. I however am not going to spend a lot of time trouble shooting it if it is buggy. If this test works out I plan on installing 4 of them. I am currently testing/using some very costly industrial cameras and this will be a much better rout if it works.
David Newman
January 26, 2007 at 10:26 pmRe: “I too would like a standalone app to capture with!”
We have the Intensity working with the Sony HVR-V1U (with 24p extraction from 60i) working through CineForm’s HDLink utility; compressing to CineForm AVIs in RT of course. This is a standalone application. Expect the update to be out soon.
– David Newman
– CTO, CineForm
– web: http://www.cineform.com
– blog: cineform.blogspot.com -
David Newman
February 14, 2007 at 4:48 amThe Decklink Intensity support is out now within all CineForm products.
– David Newman
– CTO, CineForm
Gerard Weemhoff
December 19, 2008 at 8:39 amHi David,
I read that you’ve working a HVRv1 with a intensity card. I’ve problem with that: Only PAL capture, no 1080i50. See also my threat only pal with intensity pro)
Are you recognize this problem…Do you have any solution,
Kind regards Gerard
