Activity › Forums › Blackmagic Design › BM Intensity 2nd HDMI port in Windows
Posted by Joedully on February 20, 2007 at 6:44 amI am a bit confused about the usefulness of the second HDMI port on the Intensity card in windows. As far as I know there is no way to use a monitor for preview on the Intensity so what can the port be used for? I have a camera ingesting through one port on the card but is that all that the Intensity can do?
Walterdr replied 19 years, 7 months ago 3 Members · 7 Replies -
Kristian Lam
February 20, 2007 at 9:15 amHi,
[joedully] “As far as I know there is no way to use a monitor for preview on the Intensity so what can the port be used for?”
Not sure what you mean by this. There are lots of HDMI displays out there and you can use Intensity with those.
regards
Kristian Lam
Blackmagic Design -
Walterdr
February 20, 2007 at 1:43 pmdear Kristian,
can you post some generic requirement of the hdmi monitor for Intensity?
Like resolution (1366X768 is ok?) and others. Thx -
Joedully
February 20, 2007 at 10:47 pmKristian, In a previous post you said…
“Intensity outputs YUV not RGB. Your Dell or any computer monitor will expect an RGB signals via DVI-D. Intensity does not adjust the framerate of the video to what is expected by the monitor unlike the HDLink.”
Sorry that I didn’t clarify that I was referring to HDMI->DVI displays… I am using the Intensity in the field and a …true… 1080i/p capable HDTV is a bit much to lug around (unless there is a small one made that I am not aware of) I am currently using DVI displays (on other HDMI and DVI ports), that are 1920×1600 (16×10) and they are manageable for transport and live monitoring of 1080i/p.
Thanks – Joe
Kristian Lam
February 21, 2007 at 5:52 am[walterdr] “can you post some generic requirement of the hdmi monitor for Intensity?
Like resolution (1366X768 is ok?) and others. Thx”Yes, 1366×768 is fine. As long as the monitor is able to handle a 1920×1080 signal via HDMI, then it’s ok. You’ll find that it will work majority of the displays with HDMI input such as Sony and Panasonic.
regards
Kristian Lam
Blackmagic Design -
Kristian Lam
February 21, 2007 at 5:54 amHi Joe,
Yeah, I was referring to displays with HDMI inputs. The smallest I know of is the BenQ 24 inch. Unfortunately, it stretches everything to fit the screen which is not ideal. I think it is only a matter of time before smaller displays gain HDMI connectivity (with 1:1 scaling) though.
regards
Kristian Lam
Blackmagic Design -
Joedully
February 21, 2007 at 9:32 amThanks, much appreciate the info as I plan on scaling up use of the Intensity.
Joe
Walterdr
February 21, 2007 at 6:12 pmThx for reply. We are all fantastic.
So, if new HDMI BenQ stretches everything,
I suppose that this doesn’t happen whit ldc with 1366X768 resolution
and I can work in 720p as 576i indifferently. It’s corrected?
