Activity Forums Apple Final Cut Pro Legacy blurry PNG files? Anyone have a way to remedy this?
  • blurry PNG files? Anyone have a way to remedy this?
    Posted by Chris Lonergan on February 17, 2007 at 11:06 pm
    when i bring a png file from photoshop into FCP 5.1.3, it looks fine in the Viewer.
    but then when i drop it into the timeline it gets fuzzy and the text gets blurry.
    is there a way to maintain its integrity when exporting this?
    BTW, i was exporting from photoshop using the default setting in Photoshop for DV (720×480)
    thanks
    Shane Ross replied 19 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    February 17, 2007 at 11:20 pm
    First off:
    Shane’s Stock Answer #2: Blurry playback
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL NTSC MONITOR, OR AT LEAST A TV.
    1. Disable overlays on the canvas
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline
    https://docs.info.apple.com/article.html?artnum=24787
    Video playback requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or NTSC monitor routed thru your camera or deck.
    Second, When you put this high quality image in a DV timeline it incurs the horrible DV 5:1 compression of the DV timeline. If you were working on a higher resolution timeline, like DV 50 or DVCPRO HD or 8-bit uncompressed, then your pictures would look better.
    Shane
    Littlefrog Post
    http://www.lfhd.net
