blurry pictures
Posted by Cindy Allen on February 20, 2011 at 3:57 amI read some other posts about this. I went back and resized my pictures like it said but that did not seem to help. So frustrated because the pictures are fine but not once I put them in Vegas. Please help!
Mike Kujbida replied 15 years, 6 months ago 3 Members · 6 Replies -
Mike Kujbida
February 20, 2011 at 5:33 amIf your Preview window is set to anything other than Best/Full, you won’t see the best quality picture.
Cindy Allen
February 20, 2011 at 3:41 pmOk. It was set on Best (auto). I changed it to best full but my pictures are still blurry. :o(
Danny Hays
February 20, 2011 at 4:20 pmI get tht same problem when I add HD videos to a SD project.
Try File, Properties, and set template to HD 1080-60i (1920×1080, 29.970 fps) and see how the pics look. Hope this helps, Danny Hays -
Cindy Allen
February 20, 2011 at 5:21 pmThese are photos for a slide show not video, don’t know if that matters. Where are you going to file? Vegas? I can’t find “set template”.
Cindy Allen
February 20, 2011 at 10:07 pmOk, I found where to change that setting and I get a clear picture when set on HDV 720-30p (1280×720, 29.970 fps). My proble now is when I am watching the preview it will suddenly change from Best (full) to preview (half). Do you know why it does this? Is there a way to stop that or does it matter as long as when I render it is on best full?
Thanks for trying to help!
Mike Kujbida
February 21, 2011 at 4:28 pm“My proble now is when I am watching the preview it will suddenly change from Best (full) to preview (half). Do you know why it does this?”
This is one of many new features that was introduced in Pro 9.
“Is there a way to stop that…”
Vegas can now automatically adjust the video preview size and quality to optimize frame rate during preview.
Right-click the Video Preview window and select Adjust Size and Quality for Optimal Playback if you want to emphasize frame rate during preview. When the command is not selected, video quality is emphasized, and the frame rate will be reduced if necessary.
“…or does it matter as long as when I render it is on best full?”
Your Preview window settings have no effect on your render settings.
What does matter is what render setting you choose.
Since there are stills in it, make sure to set any render mode uou use to Best.
