Activity Forums Adobe Premiere Pro blurry moving stills
  • blurry moving stills
    Posted by Tim Mccarthy on June 20, 2007 at 4:39 pm
    I’m using some moving stills on a background. I have imported some decent sized images from the web for these particular ones. When I get them in there and set up to slightly grow, they get blurry when in motion and the top and bottom edges seem like they can’t keep up with the re-scaling effect. I tried rendering the sections, but it didn’t help. Any ideas?
    Tim Mccarthy replied 19 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Harm Millaard
    June 20, 2007 at 6:11 pm
    A moving still seems like a contradictio interminis. Growing stills makes them blurry, because you are adding things that are not there to start with.
  • Vince Becquiot
    June 20, 2007 at 7:00 pm
    Are you looking at the preview window, or at a final DVD.
    The preview window isn’t a good assessment of the final product, and will dispay a non-rasterized version.
    Also, what settings are you using?
    Vince
  • Blast1
    June 21, 2007 at 5:17 am
    [tim_mc_psulaw] “I have imported some decent sized images from the web for these particular ones.”
    What is the pixel size of these images?
  • Tim Mccarthy
    June 21, 2007 at 12:49 pm
    I am looking at the program window in PP2. The blurriness when playing the sequence goes away when I change the quality to “highest” in the program monitor. But the top and bottom edges still seem like they are flickering or not keeping up with the rescaling effect.
    What do you mean by settings?
  • Tim Mccarthy
    June 21, 2007 at 12:59 pm
    The sizes of the images are 400w x 599h(300 dpi), 451w x 500h(72 dpi), 1200w x 1515h(300 dpi) and 283w x 383h(72 dpi).
    The two at 72 dpi are from the web. I have some others of similar sizes and resolutions that I’m also using.
  • Vince Becquiot
    June 22, 2007 at 5:14 am
    Even at highest quality setting, you won’t see true version of the final export. Do an export to DVD, or high quality windows media, or use an external monitor.
    Cheers,
    Vince
  • Tim Mccarthy
    June 22, 2007 at 11:56 am
    Thanks.
