Activity Forums Apple Final Cut Pro Legacy Blurry in Super Slow motion
  • Blurry in Super Slow motion
    Posted by Graham` Adams on April 2, 2011 at 1:54 am
    Hi my name is Graham and I make action sports films and was wondering what the best way to get that blurriness that occurs when you use optical flow to make a movie in 60fps even slower I use a Panasonic P2 so I know the camera is defiantly clear enough at 720p to be able to pull it off but I still get a blurry video was wondering if theres a plug in or away I can fix that thank you
    Graham` Adams replied 15 years, 5 months ago 4 Members · 4 Replies
  • Zane Barker
    April 2, 2011 at 2:37 am
    What you really should do is shoot at a faster frame rate.
    For example if you could shoot at 60fps instead of say 30fps you have 2x the number of frames each second.
    The more frames per second you shoot the the slower you can play back the video with it still looking good.
    **Hindsight is always 1080p**
  • Chris Tompkins
    April 2, 2011 at 3:18 pm
    If you want to record Slow motion in camera you choose Variable Frame Rate (VFR) Then you shoot over cranking. Choose 60 FPS in 720p/24 VFR
    Then it’ll play back in slow motion in your 24fps sequence.
    Now, blurring will come from a slower Shutter speed.
    Try some test shots with a higher and slower shutter speeds to get the results you are looking for.
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    April 2, 2011 at 6:03 pm
    Make some tests rising the shutter speed.
    rafael
    http://www.nagavideo.com
  • Graham` Adams
    April 4, 2011 at 5:17 pm
    yes thats true but Gopro videos show otherwise and I no if you take optical Flow enhancement on Final cut pro you can actually slow the frame rates down even more starting with 60 fps and up check out this video
    he pushed the 1000fps just by editing, he used a canon T2i which only shoots in 60fps max
    https://www.youtube.com/watch?v=-u_etvz1Zz8&feature=channel_video_title
