Activity Forums Adobe Premiere Pro Blurry Imported Footage
  • Blurry Imported Footage
    Posted by Richard Stegall on April 29, 2009 at 8:43 pm
    I have a good quality .mov file that is 640×480. When played independently it looks great but as soon as I put it into premier it gets degraded, what could be the problem?
    Richard Stegall replied 17 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Richard Stegall
    April 29, 2009 at 9:01 pm
    It is set on highest quality. What does my sequence need to be set up as?
  • Eddie Lotter
    April 29, 2009 at 9:03 pm
    It’s like that your project (or sequence) settings don’t match your source clip.
    It’s also possible your source or program monitor is set to draft quality.
    Cheers
    Eddie
  • Eddie Lotter
    April 29, 2009 at 9:09 pm
    The same as your clip.
    Cheers
    Eddie
  • Richard Stegall
    April 29, 2009 at 9:43 pm
    So 640×480 and whatever frame rate I am running
  • Jon Barrie
    April 29, 2009 at 11:35 pm
    What are the clip properties?
    right click the clip in the project panel…
    – Jon 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Richard Stegall
    April 30, 2009 at 2:09 pm
    Here are the properties for the file. I was wrong we are using an AVI file @ 720×480 but it still gets heavily degraded upon import. I have also included links to screen shots of the difference.
    https://67.211.7.195/import.jpg
    https://67.211.7.195/source.jpg
    File Path: F:MediaHVRrecon101Manheim3dccFixed_8.avi
    Type: AVI Movie
    File Size: 6.6 GB
    Image Size: 720 x 480
    Pixel Depth: 32
    Frame Rate: 25.00
    Source Audio Format: 32000 Hz – 16 bit – Stereo
    Project Audio Format: 32000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:37:30:14
    Average Data Rate: 3.0 MB / second
    Pixel Aspect Ratio: 0.9091
    Created with: Adobe After Effects 9.0
    AVI File details:
    Contains 1 video track(s) and 1 audio track(s).
    Interleave: 1 : 25.00
    Video track 1:
    Size is 6.28G bytes (average frame = 122.18K bytes)
    There are 56264 keyframes.
    Frame rate is 25.00 fps
    Frame size is 720 x 480
    Depth is 24 bits.
    Audio track 1:
    Size is 274.72M bytes
    Rate is 32000 samples/sec
    Sample size is 16 bits
  • Eddie Lotter
    April 30, 2009 at 4:20 pm
    I’m not sure how you can confuse a 640×480 .MOV file with a 720×480 .AVI file, but things get even more strange.
    720×480 is an NTSC resolution but 25 fps is a PAL frame rate.
    From the information you provided I recommend you create a new project using a PAL DV preset, but change the preset options to “Desktop”, change the resolution and pixel aspect ratio to 720×480 and “0.9” respectively. Now import the clip into this project.
    Cheers
    Eddie
  • Richard Stegall
    April 30, 2009 at 4:49 pm
    Sorry for the confusion, I was giving the file info secondhand by a coworker I will try the settings and report back. Thanks for all the help. You guys are the experts.
  • Richard Stegall
    May 4, 2009 at 7:39 pm
    Thanks for the help guys. The projects did not match. It is crystal clear now.
