Activity Forums Adobe After Effects Blurry Animation codec result
  • Blurry Animation codec result
    Posted by Mark Jores on October 21, 2008 at 11:40 am
    Got a quick query
    I’m having to do a short edit in after effects using a WMV for footage (my hands are tied with using WMV unfortunately) – then exporting it as apple uncompressed or animation. When I bring the render back in to AE & lay it over the original footage to check, I can see I’m getting some slight blurring of details & a bit of frame shifting throughout – like its slightly out of sync, like due to deinterlacing though no deinterlacing is being done.
    Is this a common problem with using heavilly compressed WMV footage as a source or am I expecting too much from the apple none & animation codecs?
    The source footage is a 15 fps 256 kbps wmv with compression artifacts. The project is for web broadcast & nothing is interlaced. None or animation codecs are set at max quality.
    Mark Jores replied 17 years, 11 months ago 24,900 Members · 1 Reply
  • Mark Jores
    October 21, 2008 at 3:50 pm
    Ah but I’m not trying to improve it, just edit it slightly (I removed 5 secs of someone talking about something irrelevant) – the video becomes slightly blurred after rendering it out in AE to Animation codec or None, so I am still losing what fine details I have left at this stage when I shouldnt be…its meant to be lossless at this point.
    I’m used to working with blackmagic or sheer compressed footage & not noticed this happening.
    I was wondering if this was an inevitable side effect of using WMV footage or the Apple codecs I’m using?
