Blurred Image Sequence
Posted by Jake Huddleston on March 24, 2009 at 11:25 pmI need to make the frame rate of the image sequence I am importing the same as the frame rate set on Vegas, thus preventing the blurriness I am encountering when playing the image sequence on my timeline. How do I do this?
– Jake H.
John Rofrano replied 17 years, 6 months ago 2 Members · 5 Replies -
John Rofrano
March 25, 2009 at 2:40 amYou set the framerate when you import the images. You’ll have to import them again to get the framerate window again. It pop’s up right after you tell Vegas which images to import.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Jake Huddleston
March 25, 2009 at 5:09 amI have already set the frame rate for my image sequence, and it fits perfectly into my project as of now. I could change it, but it would be very difficult to fit it in if it were changed. My question is, can the VEGAS frame rate can be changed to match my imported image sequence? I have tried doing this, but it never seems to match up and the blurriness continues…
– Jake H.
John Rofrano
March 25, 2009 at 2:39 pm> an the VEGAS frame rate can be changed to match my imported image sequence?
Yes just change the frame rate in your project. You can also turn off Resample on the event so that Vegas doesn’t try and interpolate the footage.
What frame rates are we talking about here? What’s the frame rate of your image sequence and what’s the frame rate of your project?
~jr
Jake Huddleston
March 25, 2009 at 3:37 pmThanks! I disabled the Smart Resample option and that solved my problem. Thanks again.
– Jake H.
John Rofrano
March 25, 2009 at 5:31 pm
