Activity Forums Adobe After Effects Bluring Objects Behind A Layer
  • Bluring Objects Behind A Layer
    Posted by Josh Hopkins on October 14, 2017 at 7:17 pm
    Hiya, I’ve been watching a bit of YouTube and messing around on After Effects (As you do) and have came across something which I would like to know how to do. Whilst watching CloudKid on YouTube I saw that behind the outer circle, everything was blurred
    As pictured:
    I have tried following this fourm: https://forums.creativecow.net/thread/2/850640 but found it confusing, and didn’t have any luck.
    If anyone can help me with this, I would appreciate it ????
    Thanks in advance!
    Josh Hopkins
    Josh Hopkins replied 8 years, 10 months ago 2 Members · 2 Replies
  • Jim Scott
    October 14, 2017 at 10:09 pm
    Add an adjustment layer between the background and the white circle. Create a circular mask on the adjustment layer and set it to Add (or Subtract with Inverted checked). Add a blur effect to the adjustment layer.
  • Josh Hopkins
    October 15, 2017 at 8:36 am
    Yes! Thank you so much, I’ve been trying to figure this out for AGES and this has done the job! Thanks again ????
    Josh Hopkins
