Activity Forums Adobe Encore DVD BluRay with HD Menues won’t work
  • BluRay with HD Menues won’t work
    Posted by Andrea Hofmann on August 5, 2011 at 9:18 am
    I’ve created a blu-ray project with nine HD menues (1920×1080, 72dpi, RGB) and 13 films in 1920×1080 29.97i mgeg2.
    No error messages while burning, but the Bluray won’t play in two different players.
    If I build the same blu-ray project but with menues in 720×480 and still the same HDfilms, everything works fine.
    Has anyone experience why this is? According to Adobe Encore, I’m able to use full HD menues..
    Thanks for your help
    Andrea
    Andrea Hofmann replied 15 years, 1 month ago 2 Members · 2 Replies
  • Daniel Ludwig
    August 5, 2011 at 9:43 pm
    hey andrea,
    there are several reasons why you BD wont play on standalon-players.
    – bad media
    – to high bitrate
    – standalone player can´t playback BD-R
    I´ve created a lot BDs using adobe encore – also BDs that has gone to replication – they are all working fine.
    I guess it´s depending on your encore-version. I have been using CS4 or CS5 and I know encore CS3 is a big, big mess…
    I also would like to advice to use high quality media like verbatim or tayo juden.
    habe you burned from within encore? if you burned these BDs with another burning-programm you might use the wrong file-format as well.
    Blu-ray needs to have the UDF2.5-format.
    cheers
    danny
  • Andrea Hofmann
    August 8, 2011 at 12:39 pm
    Hi Danny,
    thank you for your help.
    Probably the disc was bad, as it worked now with a different one.
    Cheers
    Andrea
