Activity Forums Adobe Premiere Pro BLURAY with 1080P and 25fps
  • BLURAY with 1080P and 25fps
    Posted by Akbar Basha on October 18, 2011 at 10:39 am
    Hello,
    I have just completed editing a project which was shot using 5D in 1080P at 25fps. Now I want to export the project and burn it into a Bluray disc. Unfortunately i was unable to find a progressive format with 25fps(PAL), there is only upper or lower is available in the field option but when i choose NTSC, I get the Progressive(No Fields)option available. Now my project is 1080P and 25fps, how can I make a bluray disc without adding fields or changing the framerate.
    Akbar Basha
    Akbar Basha replied 14 years, 11 months ago 2 Members · 2 Replies
  • Hampus Lager
    October 18, 2011 at 5:09 pm
    You can’t. Bluray don’t except 25p, just 24p. Either export as 50i or export the file as 1080p25 with Prores or DNxHD (or whatever), import that into the project and make a 24p timeline and intepret the new file to 24p (this will make to video go 4% slower, the opposite of PAL speed-up that is used for DVDs when converting movies with 24fps to PAL 25fps.
  • Akbar Basha
    October 18, 2011 at 5:19 pm
    Thanks Lager..
