Activity Forums VEGAS Pro BluRay via DVD Architect Pro 5
  • BluRay via DVD Architect Pro 5
    Posted by Lucas Cheadle on October 1, 2008 at 8:42 pm
    MacBook Pro 2.5GHz, 4GB Ram
    Trial version of DVD Achitect Pro 5
    Final Cut Studio
    LG BE06 external BluRay burner
    I’m treading cautiously through murky waters…
    The goal: delivery of HDV wedding on BluRay.
    Obstacle: BluRay authoring software
    Adobe Encore? Bad reviews and too expensive.
    I’ve created a test project in DVD Architect. It won’t burn but it did create an .iso file.
    Questions:
    Is the trial version crippled?
    Can I expect to successfully burn BD with DVD Architect once it’s paid for? Or rather, is there anyone out there using the same set-up as me making BDs?
    What about Toast 9 and the HD plug-in?
    If DVD Architect will operate fine alone then I’d prefer not buying Toast.
    David Shirey replied 17 years, 11 months ago 3 Members · 2 Replies
  • John Rofrano
    October 2, 2008 at 1:05 am
    It must be a trial limitation. The retail version also makes an ISO file but it will then burn it for you. I’ve burned Blu-ray’s on my Pioneer BD-RW BDR-220 and DVD Architect 5 works great.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • David Shirey
    October 2, 2008 at 2:29 pm
    So you’re editing in Final Cut Studio on your MacBook Pro, then using bootcamp to load WinXP to use DVD Architect? I’ve never tried that setup, but as long as the burner works then DVD Architect should burn it fine. I have successfully burned blu-rays both from Vegas, and also iso’s that we transferred over from Encore on our macs.
