Activity Forums VEGAS Pro BluRay Surround Sound Issue
  • BluRay Surround Sound Issue
    Posted by Dave Edwards on November 2, 2009 at 10:24 am
    When I import Dolby AC3 5.1 sound into DVD Architect 5 from Vegas 9c I see only two tracks in Architect: the “left” track (if that is what it is) is very quiet whilst the “right” is normal or loud.
    I found a poster elsewhere with this problem, incidentally, and a response that Architect “shows” the 5.1 as a stereo mix but does create 5.1: on the strength of this I burnt a BluRay disk based on this but the audio was indeed skewed as described above.
    It //may// be 5.1 (I can’t tell due to the low volume levels on some chennels) but is unusable.
    The same project in stereo is absolutely fine.
    Dave Edwards replied 16 years, 10 months ago 2 Members · 4 Replies
  • Rob Franks
    November 2, 2009 at 12:13 pm
    Are you using the “PRO” encoder or the “STUDIO” encoder?
  • Dave Edwards
    November 2, 2009 at 1:43 pm
    Studio. Is this a problem?
  • Rob Franks
    November 2, 2009 at 10:30 pm
    Yes… it’s a problem.
    I have seen the same issues with the studio encoder. Not to mention the fact that the studio encoding (99 times out of 100) gets re-encoded in DVDa anyway. The studio encoder is not certified in any way, shape or form and therefore…. stinks (to put it mildly 🙂
    If you use the Pro encoder you will not get this issue and you will also never re-encode (provided of course your encoding meets the proper standards)
  • Dave Edwards
    November 3, 2009 at 9:22 am
    Thanks, Rob: problem solved.
