Activity Forums VEGAS Pro BluRay from 720p @ 25fps
  • BluRay from 720p @ 25fps
    Posted by Chris Morley on April 9, 2013 at 8:47 am
    Hello there,
    Can someone tell me the best settings, in Vegas Pro 8 & DVA5, for rendering a 720p 25fps file into a BluRay disk? I’ve looked around and it seems that this may be problematic, so i’m hoping someone will have done it before and could just give me the settings. It’s quite urgent as the client has insisted that they want a BluRay.
    Chris.
    John Rofrano replied 13 years, 4 months ago 2 Members · 3 Replies
  • John Rofrano
    April 10, 2013 at 6:32 pm
    [Chris Morley] “Can someone tell me the best settings, in Vegas Pro 8 & DVA5, for rendering a 720p 25fps file into a BluRay disk?”
    No because 1280×720-25p is not supported by the Blu-ray specification. You can have 1280×720 at 60p, 50p, or 24p but not 25p.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chris Morley
    April 11, 2013 at 10:49 am
    Hi John, many thanks for the reply.
    Do you know of any work-arounds for me successfully getting this footage on to BluRay?
    Chris.
  • John Rofrano
    April 11, 2013 at 4:58 pm
    [Chris Morley] “Do you know of any work-arounds for me successfully getting this footage on to BluRay?”
    You can’t get around the spec. Your options are to render 720-60p, 720-24p, or 1080-50i. I would probably choose 720-24p since it’s so close to the 25p that you already have.
    ~jr
