Activity Forums Compression Techniques BluRay done Half Way…
  • BluRay done Half Way…
    Posted by Darren Peister on March 7, 2011 at 1:40 pm
    Using Compressor, I squoze an HD file down to fit a single layer BluRay blank disk. The program created an “.ac3” file and a “.264” file onto my hard drive but then failed to burn the disc! How can I take these two existing files and make a BluRay disc? Do I need Toast? Thanks
    Geek/Nerd
    Mac Pro 2.26 GHz Quad-Core Intel Xeon
    16 GB RAM, 3Gig internal Raid
    Michael Kammes replied 15 years, 6 months ago 3 Members · 2 Replies
  • Craig Seeman
    March 8, 2011 at 11:26 pm
    You do have a Blu-Ray burner don’t you? I assume nothing unless the information is included.
    You should look at your Compressor log and see if you can find the cause of failure.
    Toast would work in theory although I haven’t tried this. If your computer is having problems communicating with the drive than Toast may run into the same problem.
  • Michael Kammes
    March 9, 2011 at 2:42 pm
    Yes, the Mac, by default, does not have a BD drive. Compressor, as you see, can create the h.264 and ac3, which you will have to manually use these in software (like Toast) and get a 3d party burner.
    Did you use the wizard in Compressor? Or just the preset for a blu-ray disc?
    You may want to looking into burning an AVCHD disc (lower bitrate AVCHD / blu-ray compliant file) onto a red laser (SD) disc. This works well for shorter projects and delivers very good HD results.
    https://www.kenstone.net/fcp_homepage/burn_br_mac_superdrive_stone.html
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    .: twitter: @michaelkammes
    .: facebook: /mkammes
    Hear me pontificate: Speaking Schedule .
