Activity Forums VEGAS Pro BluRay Crash
  • BluRay Crash
    Posted by Wade Harrington on January 18, 2008 at 5:24 am
    I’m trying to render and HD file to bluray from tools burn bluray. and at the end of the render I get the following error message..
    Filename: STREAM/00001.m2ts
    Status: TSWrapper.dll::CTSWrapper::ProcThreadMain::IO Error — Failed to open file: ‘G:\Documents and Settings\Wadro\Local Settings\Application Data\Sony\Vegas Pro\8.0\~bdmux3112\media\Untitled.w64.ves’ –
    Any one have any suggestions?
    Wade Harrington replied 18 years, 7 months ago 1 Member · 1 Reply
  • Wade Harrington
    January 22, 2008 at 2:32 am
    sorta found a workaround
    https://www.sonycreativesoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=571687
    last post states:
    I’VE SOLVED THE PROBLEM!!!
    Now, if you make the m2ts -stream using Tools – Make Disk – Blu-Ray Disk… the resulting file:
    a) works, no audio lagging or picture freezing
    b) even Vegas correctly regocnizes the file and can import it to timeline. It extracts the surround audio also to four separate tracks (Front, Rear, LFE and Center
    Now: could someone PLEASE inform Sony people of this…
