Activity Forums Adobe Encore DVD Bluray compression issues, glitches & artefacts
  • Bluray compression issues, glitches & artefacts
    Posted by Travis Collins on April 3, 2019 at 8:42 am
    Hi, I have been authoring a blu-ray for the master of my film and the quality is very low. There are hundreds of very detailed paintings and drawings and there are glitches and digital artefacts that appear on the blu-ray in nearly every image. I exported both H264 Blu-Ray and MPEG Blu-Ray from premiere at maximum render quality and authored in Encore. The H264 version is marginally better but it’s definitely not good enough to be screened.
    I exported a regular H264 to compare and the quality is much better. I don’t know if it’s the H264 Blu-Ray codec that is causing the issue or if the problems come from Encore.
    Can anyone please help? This is urgent.
    Jeff Pulera replied 7 years, 5 months ago 2 Members · 1 Reply
  • Jeff Pulera
    April 3, 2019 at 4:01 pm
    Hi Travis,
    Please provide a screen shot of the Export Settings used in Media Encoder. That will be a good starting point to look for issues.
    Also, how are you viewing the finished Blu-ray disc? This could possibly be a player issue, need to rule that out and determine if the actual video clip you created has glitches. You should be able to play that clip right from the Premiere timeline or maybe in VLC player for example and see how it looks there.
    Jeff Pulera
    Safe Harbor Computers
