Activity Forums Apple Final Cut Pro Legacy BluRay Archive Question
  • BluRay Archive Question
    Posted by Craig Johnson on February 16, 2011 at 2:37 am
    Hello All,
    On a BluRay disc, is the BDMV file the Video-TS file equivalent of a SD DVD file. If so, can it be archived and then brought into Toast at a later date and be made into another BluRay?
    One more….can I use any DVD copy software such as Nero to burn a copy of a BluRay?
    Regards
    Craig Johnson replied 15 years, 6 months ago 2 Members · 2 Replies
  • Rafael Amador
    February 16, 2011 at 5:21 am
    yes, you can rip a BR and use the media to build a new one.
    Nero works for PC.
    I guess that non commercial BR can be copied with Toast. No idea about BR that have protection.
    Here they mention an application to rip BRs:
    https://forums.creativecow.net/readpost/200/891183
    rafael
    http://www.nagavideo.com
  • Craig Johnson
    February 16, 2011 at 1:39 pm
    Thanks for your response.
    These are my projects, and this is the ongoing archival process that we discussed in my previous thread stemming from DVD disc failure.
    I did try to take my BDMV file and drag it into Toast 10, it has a place to drag these file types. It appeared to be burning but just ejected a blank BluRay, but the when I tried to use the same disc over again for another experiment, Toast says the BluRay isn’t blank. Don’t want to keep making coasters. Have any of you done this? Can I have your workflow? I can’t imagine I’m far off the mark but murdering quality blanks can get pricy.
    Thanks.
