Activity Forums Adobe After Effects Blur transition
  • Blur transition
    Posted by Seanwinn on February 2, 2007 at 11:17 pm
    Does anyone know if AE will, or if there is a plugin (not too expensive) that creates a blur transition between shots?
    Thanks…
    Rjf E:613 replied 19 years, 7 months ago 3 Members · 4 Replies
  • Kuaishou
    February 3, 2007 at 11:06 am
    hi…the blur transition can be done by doing a dissolve between your 2 clips…then add an adjustment layer where u add your blur in/out…hope it helps…cheers…merv
  • Seanwinn
    February 3, 2007 at 8:10 pm
    Thanks Merv, that does work. What I was trying to base it off of is a plugin from Eureka (or a Eureka plugin) for Final Cut that does this automatically – it’s called ‘blur through’ I believe but would more acurately be termed timewarp tranistion in my opinion as it stretches one scene into another. Was hoping to find an AE plugin that eliminated these manual steps…
    Anyway, it worked – thanks!
  • Kuaishou
    February 5, 2007 at 5:09 am
    anytime bro…im new to AE too so im learning from u too by replicating your problems and trying to figure it out…:)…cheers…merv
  • Rjf E:613
    February 5, 2007 at 6:57 pm
    Andrew Kramer has a nice blur transition he sets up during this tutorial:
    https://forums.creativecow.net/articles/kramer_andrew/slideshows/slideshow.htm
    You can save this as a preset for use whenever you need it.
    rjf
