Activity Forums VEGAS Pro Blur showing up after rendering
  • Blur showing up after rendering
    Posted by Jimmy Cressy on July 15, 2012 at 12:00 pm
    I have been taking videos of my golf swing lately. When watching the raw viedeo there is ablolutly no blur. But after rendering it in sony vegas there is lots of blur/ghosting on the club.
    Does anyone know if there is a way to get rid of this, or is something I’m going to have to live with.
    When I am watching the raw AVCHD.mts format, there is no ghosting at all.
    Here is an example of what I am talking about.
    https://www.youtube.com/watch?v=VbuECiLSjvs&feature=relmfu
    Matt Crowley replied 14 years, 1 month ago 2 Members · 1 Reply
  • Matt Crowley
    July 16, 2012 at 6:40 pm
    You’ve discovered Vegas’s automatic deinterlacing. For high-motion subjects, try setting your project’s deinterlace method to “interpolate” instead of the default “blend”. This gives a small reduction in vertical resolution but avoids the ghosting you are seeing.
    In addition, if you simply stretch a video event to slow it down, Vegas has to make up extra frames somehow, and by default is uses the same blend method to resample the source frames. Try disabling “resample” by right-clicking on the video event on the timeline, then select Switches -> Disable Resample.
    This will not give smooth slow motion – you need separate motion interpolation effects such as Twixtor or some trickery with frame rates and intermediate renders to get better slo-mo. The best way of course is to use a special camera with a very high frame rate.
