Activity › Forums › Adobe After Effects › Blur on solid layers tha affects the ones below it
  • Blur on solid layers tha affects the ones below it
    Posted by Joao Laureano on September 28, 2011 at 8:18 pm
    This should be really easy to do but I can’t seem to get it right.
    I’m trying to include a blur on a solid layer in a way that it also affects the ones below it.
    I’ve attempted to do so by adding an adjustment layer and pre-composing them, and also playing with the blending modes – but once I move the new comp to other composition with footage the blur is missing.It happens even if the solid and adjustment layer have the same size.
    The solid with blur will work as a bg for text, as on the example below:
    https://vimeo.com/21381136
    Anyone has an ideia of how to achieve this? Its important that I can move the solid freely and redimension it, since it will be animated,
    Thanks in advance
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Ben G unguren replied 15 years ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    September 28, 2011 at 8:41 pm
    Animate a solid (any color) as you need it to be positioned, rotate… Then render out a matte (black and white image) for the solid only. Comp the background on top of itself, use the matte of the solid to cut a hole in the top layer and blur as you need the bottom.
    This should give you the effect you’re after.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    September 28, 2011 at 8:51 pm
    One more idea- if you need to be able to tweak the animation of your solid, use the same idea only precomp the solid and use the precomp layer as a track matte to cut a hole in the top layer of the bk in order to reveal the blur underneath.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Joao Laureano
    September 28, 2011 at 9:11 pm
    Worked great thanks for the prompt feedback!
  • Ben G unguren
    September 28, 2011 at 9:27 pm
    Note that a precomped adjustment layer will continue to act as an adjustment layer in the upstream comp ONLY if you have the Collapse Transformations switch enabled. This is actually a very fun technique that can be a bit tricky to manage….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
