Activity Forums DaVinci Resolve Blur mask not corresponding
  • Blur mask not corresponding
    Posted by Jean Tertrain on December 27, 2023 at 2:15 pm
    Hey,
    I’m having a hard time with my blur masks.
    As you can see, I put my opacity on 0, but it does nothing (Yellow blur on the image).
    (I need my blur to fade out).
    I’m trying to modify my keyframes, but they are so tiny I can’t even click on them.
    What a pain.
    Thank you if you have any tips,
    Jean
    Jean Tertrain replied 2 years, 8 months ago 2 Members · 2 Replies
  • Jamie Dickinson
    December 27, 2023 at 5:32 pm
    The parameter values usually don’t correspond when in between keyframes, which makes it very confusing. Be sure you have the auto keyframes enabled in the correct node in the Keyframe menu and use [ and ] to jump between keyframes, making sure you set the value correctly on each other keyframe.
  • Jean Tertrain
    December 28, 2023 at 1:12 pm
    Thanks Jamie. Where is the “Keyframe menu” please ?
    I don’t even have the “(” you mention on my keyboard.
    Second question :
    How can I make my two blur mask merge into each other ?
    As you can see, the yellow one “resists”, and the blue one is absorbed.
