Activity › Forums › Apple Final Cut Pro Legacy › blur logo tutorial
blur logo tutorial
Posted by Ralph Bertini on April 15, 2009 at 9:51 pmIs there a tutorial to blur a logo on a tshirt?
Ralph Bertini replied 17 years, 5 months ago 3 Members · 3 Replies -
Dennis Leppell
April 15, 2009 at 10:47 pmhow bout I write one for you.
Duplicate the clip needing the blur and stack it directly above the original.
add matte shape. select the size/shape you need. use the center controls of the filter to position the matte. Keyframe the matte position and size as the subject moves across the scene. ABSOLUTELY DO NOT USE THE CENTER CONTROLS IN THE MOTION TAB. You MUST use the center controls of the filter.
Add a gaussian blur, and crank the settings for desired effect.
Tweak the size/shape and position as needed. If the edges are a little harsh, add the mask feather filter.
Another way to do this, but more time intensive is to use the 4 point or 8 point garbage matte.
David Mcgiffert
April 17, 2009 at 3:53 pmGood tutorial Dennis,
I have used something close to this method
and have been very happy with the results.David
Ralph Bertini
April 19, 2009 at 3:10 amThanks for your time. I’ll give it a try.
“Life is happens when your busy making other plans” -John Lennon
