Activity › Forums › Apple Final Cut Pro Legacy › Blur-Dissolve – Video Transition
  • Blur-Dissolve – Video Transition
    Posted by Beau Brotherton on July 25, 2007 at 6:51 pm
    I just saw a video of a wedding and saw a transition that I liked. It was like a dissolve, kind of. Basically it blurred the transition point, so that the out clip went out of focus and then the in clip came into focus from the out clip.
    It was like a Blur-Dissolve.
    I looked in FCP Effects tab and couldn’t find a transition effect that did what I wanted. Does anyone know how to do this transition. Or is it just throwing the camera in and out of focus during shooting, cause that seems like it would be a pain.
    Thank you for your responses.
    Beau
    Jason Porthouse replied 19 years, 2 months ago 8 Members · 7 Replies
  • 7 Replies
  • Jacob Picorale
    July 25, 2007 at 6:56 pm
    https://www.fxscript.org/plugins.html
    This guy makes has a plug in called “stibs blur cross”. It does exactly what you’re talking about. Its shareware.
    -jake
  • Shane Ross
    July 25, 2007 at 7:03 pm
    http://www.nattress.com BIG BOX OF TRICKS.
    I used it a lot in my last show.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Rafael Amador
    July 26, 2007 at 2:53 am
    You can download for free the “Stib’s” and the “Telly’s’ plug-ins. They’ve got few different blur-transitions and they works great.
    Cheers,
    rafael
  • Chuck Spaulding
    July 26, 2007 at 3:27 pm
    What version of FCP are you using?
    Do the stibs and telly’s plug-ins work well with the fxplug in FCP6?
  • Chris Poisson
    July 26, 2007 at 3:53 pm
    The ones mentioned here work great, also, there’s one in Eureka! called bluracross.
  • Joe Murray
    July 29, 2007 at 3:14 am
    I’ve always thought someone should make a plugin that combines glow and blur as a transition and call it “glur.”
    Joe Murray
  • Jason Porthouse
    July 30, 2007 at 1:36 pm
    Put Gaussian Blur on both. Set to 0. Using keyframes, ramp up on outgoing and down on incoming- make sure keyframes for max blur are at least half the duration of your dissolve outside your clip. Apply dissolve. Bake in a warm oven for 20 mins at gas mark 5*
    Jason
    * ignore this last stage
