bluff titler
Posted by John Culleton on January 29, 2012 at 12:42 pmis bluff titler a Vegas plugin or standalone?
John Culleton replied 14 years, 7 months ago 3 Members · 7 Replies -
Chris Siers
January 29, 2012 at 6:53 pmAs far as I’m aware, it’s stand alone. I save my titles as AVI, then add the file to my project media bin.
Chris Siers
James Houghtaling
January 30, 2012 at 4:06 amDefinitely a stand alone program but very powerful for more than just slick 3D titles. Projects can easily be rendered to AVI with Alpha channel so you just drop them in Vegas time line and turn on the alpha channel (pre-multiplied dirty) under the AVI’s properties menu.
You can do some neat 3D animations and import 3D models from other sources as well. Here’s one example:
https://vimeo.com/25164477—————
My Hardware:
Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.My Software:
Vegas Pro V11 with Boris Continuum Complete 7, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff. -
John Culleton
January 30, 2012 at 7:34 pmBluff looks like a great compositor. i think that link is broken James?
James Houghtaling
January 30, 2012 at 7:52 pmI wouldn’t call it a compositor, that’s probably its weakest attribute. Particle generator is not bad, 3D titler is excellent, 3D composition yes, but it falls short when you start adding video and audio elements which you can do, just not with much control over how the file plays. That said the sample video contains elements added in vegas (smoke, fire, audio. The ground, sky, lightning bolts, text, power plant model, light and movement were all done in bluff.
BTW, the video link shows up fine for me in my previous post as a vimeo player. Here’s a Youtube link to the same:
https://www.youtube.com/watch?v=M6qhi9AD_lA—————
My Hardware:
Vegas Pro V11 with Boris Continuum Complete 7, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff.Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Culleton
February 18, 2012 at 2:57 pmit’s some little program hey, are there any forums for Blufftitler?
how do i replace a graphic in a show btw?
James Houghtaling
February 18, 2012 at 4:52 pmThere is a gallery at https://www.outerspace-software.com/gallery/index.php with examples of user shows where you can also ask questions. The developer is very active and will often answer most questions within a day or even create special effects or show examples for users.
To replace a graphic in a show you select that layer and hit F9 to change it’s properties.
My Hardware:
