Activity Forums Apple OS X bluetooth Q
  • bluetooth Q
    Posted by Todd Sali on August 12, 2005 at 11:29 pm
    Hi there,
    on my G5 (latest OS) bluetooth can take up to 10 minutes to be recognized….which makes it not reasonable to use the kb and mouse for me. is there something wrong with this or is this expected functionality? any advise?
    thanks,
    Todd
    Todd Sali replied 21 years ago 2 Members · 2 Replies
  • Tony! Hulette
    August 13, 2005 at 11:37 pm
    Make sure you attached the little Bluetooth antenna to the back of your G5. If you have a metal desk, or a 2.4 GHZ phone near by it could be interfering with the signal as well. Make sure you’ve updated the Bluetooth firmware (and software) to the latest version: https://docs.info.apple.com/article.html?artnum=86493
    Also, try these things: https://docs.info.apple.com/article.html?artnum=86496
    For more tips and possible solutions I suggest searching the Bluetooth section of Apple’s Knowledge Base found here: https://www.apple.com/support/bluetooth/
    Report back to us if you find a solution, as it may help others who are having similar problems.
    Tony!
  • Todd Sali
    September 6, 2005 at 10:27 pm
    turned out to be a busted machine.
    thanks much for the help.
    in the shop right now with the hood up. another G5 here kicks in almost immediatly with the same keyb and moouse.
    cheers,
    todd
