Activity Forums Avid Media Composer Blue/Green button !!! where is it
  • Blue/Green button !!! where is it
    Posted by Rap on November 7, 2005 at 4:28 pm
    Hi guys
    I’m editting on Avid Xpress connected to the Mojo and I was wondering why cant i see the Blue/Green buttom, and the only resolution that i have is DV and 28:1 and I dont have 1:1 !!!
    oh and the effercts are not real time anymore!!
    what is going on?
    when i start he Avid, I do get the Avid Mojo on the monitor so i guess that means that the Mojo does work !!!
    thanks in advance for any help
    Oakmozart replied 20 years, 9 months ago 2 Members · 1 Reply
  • Oakmozart
    November 8, 2005 at 10:32 pm
    Are you using XPro 5.x (XPro HD)? Did you upgrade in the middle of a project? If so, the reason your blue/green button is gone is because that is no longer in XPro 5. The blue/green button has been replaced by a “1394” button instead.
    If you’re using XPro 4.x, then it sounds like a corruption in the software, and you might have to reinstall.
    Good luck.
