Activity Forums Audio Blue Yeti Pro USB Mic – Can’t change sample rate on my Macbook Pro Retina
  • Blue Yeti Pro USB Mic – Can’t change sample rate on my Macbook Pro Retina
    Posted by Jesse Selwyn on December 7, 2012 at 1:35 am
    Not sure if this is the right place for this post, but…
    I’ve got a Blue Yeti Pro USB Mic which is capable of ‘sampling rates from 22kHz to 192kHz.’
    The place to change this setting is in Utilities –> Audio MIDI Setup.
    There’s a dropdown menu there that let’s me change the sampling rate (set to 44.1 Hz by default).
    However, anytime I select any different rate (48, or 192, or whichever), it reverts back to 44.1 after about two seconds. I can’t seem to get it to stick to anything but 44.1.
    Could this that my stock sound card is limited to 44.1 Hz?
    I’m running a new Macbook Pro Retina, 2.6 GHZ Intel Core i7.
    Any ideas? Thank you for the help!
    Jesse Selwyn replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
