Activity Forums Avid Media Composer Blue waveform in source monitor
  • Blue waveform in source monitor
    Posted by Chris Gape on January 2, 2020 at 9:59 am
    Hi, apologies if this is a basic question but I’m migrating my skills from Premiere and FCP to learn more about Avid and so I’m still at the beginners stage. I know how to edit audio in the timeline through switching to source/record but I’m trying to find out if it’s normal that I should see a big pixelated blue waveform in the source monitor everytime I load in some audio?
    Not sure if the image below posts correctly so here’s a link instead:
    https://imgur.com/gallery/kIYQUTf
    Avid Waveform
    Michael Phillips replied 6 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Phillips
    January 2, 2020 at 1:34 pm
    Yes, that is normal and has been this way since the original Avid/1 Media Composer released in December of 1989. It is only an icon representing the fact that it is an audio-only clip (and for historical trivia, the waveform is the word f**k) and has no bearing on the actual waveform presentation of the clip at that point in time. It has been a really long-time feature request to do more, even something like what is available in Source Settings, but no change yet. Switching the source/record is the workaround as you’ve discovered.
    Michael
  • Chris Gape
    January 2, 2020 at 2:18 pm
    Hi Michael, thanks for you reply. Are there any options in Avid to change it or turn it off in the source monitor?
  • Michael Phillips
    January 2, 2020 at 2:23 pm
    There are not. ☹
    Michael
  • Job Ter burg
    January 2, 2020 at 9:07 pm
    Flabbergasted. I have never ever seen that blue thing in the Source monitor. Nor do I see it when I load an audio-only clip in a project with fresh user settings…
  • Michael Phillips
    January 3, 2020 at 10:02 pm
    I believe Job is right and I did not want to be misleading – the blue/black waveform is only in the bin thumbnail view and not in the Source monitor when loading an audio-only source clip. Now why it shows up in your source monitor is quite the mystery.
    Michael
  • Paul Grote
    January 7, 2020 at 10:48 am
    I have the same issue. When you know how to fix it let me know;)
  • Michael Phillips
    January 7, 2020 at 6:38 pm
    Just went back into MC, latest version and also see the blue waveform in the source monitor:
    Michael
