Activity Forums VEGAS Pro Blue Ray & SD disk from same project?
  • Blue Ray & SD disk from same project?
    Posted by Paul Gregory on August 1, 2012 at 5:15 am
    I’m about to render out my first HD Blu-Ray disk. I also have a friend that wants a SD MPEG2 disc of same video. Is it just a case of importing the Blu-Ray into DVDA create menus & then burn disk. Then going back to DVDA & telling the program that you just want a SD MPEG 2 disc & then the program just re re renders the files using the same menu’s etc.
    If I have to create the MPEG2 file in Vegas 10 can a batch process automatically create 2 files from a queued list?
    Thanks in advance
    John Rofrano replied 14 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    August 1, 2012 at 8:12 pm
    [Paul Gregory] “Is it just a case of importing the Blu-Ray into DVDA create menus & then burn disk. Then going back to DVDA & telling the program that you just want a SD MPEG 2 disc & then the program just re re renders the files using the same menu’s etc.”
    Yes, that’s all you need to do.
    [Paul Gregory] “If I have to create the MPEG2 file in Vegas 10 can a batch process automatically create 2 files from a queued list?”
    Actually this would take longer because all of the FX and everything in your project would need to be rendered twice. It’s quicker to render to Blu-ray and then have DVD Architect create the MPEG2 from the already rendered Blu-ray version.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
