Activity › Forums › Apple Final Cut Pro Legacy › Blue Ray Disc
  • Posted by Nick Avaliani on January 11, 2011 at 8:22 am
    Hello Guys
    Tomorrow I am gonna test my movie in theater, they required blue ray disc
    Can you recommend me how I can record color corrected rendered video from FCP to blue Ray disc?
    Is there any valid work flow?
    thanks
    Nick Avaliani replied 15 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    January 11, 2011 at 10:39 am
    Hi Nick,
    The minimum you need is Toast 10 and a BR Burner.
    Toast will compress your QT movie and author (basic) the BR.
    If you want a better compression, you can use Compressor to compress the MPEG-2/MP4 for the BR and import that to Toast for the authoring.
    For more elaborated authoring Adobe Encore is the way.
    Do a search in this forum. This workflow has been explained many times.
    rafael
    PS: You can use DVDSTP to make non-standard DVDs with HD contents but they play only on Mac.
    http://www.nagavideo.com
  • Ben Holmes
    January 11, 2011 at 10:46 am
    Given they need it tomorrow? Take a quicktime to someone who can make you a disk.
    If you have a blu-ray burner (most external ones work fine with OS X, I have Pioneer internal BD in one of my towers) the simplest option is to use Toast Titanium – drag and drop an HD quicktime into Toast and let it do the rest – quick, reliable and far better quality than DVD.
    You can also burn a Blu-Ray disk within FCP using the ‘share’ option – this can be to Blu-Ray or an AVCHD disk, which can be a standard DVD-R with HD data on it. These are less compatible than actual BDs, but a good option for many.
    If you wish to take this further, you can use Adobe Encore (which tends to be a nightmare on more complicated BDs on a Mac) or I’m sure certain people here can advise you on more specialist setups. I’d guess, however, that you just want a simple ‘enter and play’ disk.
    I think you’ll be suprised how well OS X supports Blu-Ray, despite Mr. Jobs assertions. I have two external and one internal BD burner, and all work seemlessly in OSX.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Nick Avaliani
    January 11, 2011 at 11:10 am
    Hey thanks
    Is not final cut pro 7.0.3 capable of doing this? there is option in file > share > blue ray, I also watched it on youtube that it burns video on blue ray directly from FCP.
  • Walter Biscardi
    January 11, 2011 at 12:37 pm
    The share function from FCP is marginal at best and I’ve not seen a good quality disc come from that yet.
    For “Play Only” BluRay discs used at screenings and film festivals we create the MPEG-2 / AC-3 files in Compressor, then author the disc in Adobe Encore and finally burn the disc with Toast or Nero.
    For fully authored BluRay discs we use NetBlender DoStudio to author the disc.
    The BIG piece of advice – purchase a re-writeable BluRay disc for testing. You can burn and reburn it all you want without having to pay for a new BluRay disc each time. Once that works correctly, then copy it to a regular BluRay disc.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Ben Holmes
    January 11, 2011 at 5:53 pm
    I did post the above comment about 6 hours ago – sorry for apparent repitition. It appears either I or the Cow have a few virus issues….
    Edit Out Ltd
  • Nick Avaliani
    January 11, 2011 at 6:04 pm
    Hi
    What is to make the best quality?
    I was planning to give DCP to theater, but they told me they prefer Blue Ray disc. So I intend to write as good quality as possible despite it is time consuming or not
    so please advise
  • Nick Avaliani
    January 13, 2011 at 9:42 am
    I got blue ray disc, I want simply to play vide, I do not care about authoring and such matters, as far as I will take back blue ray after I test video.
    I just want to test how my color correction looks like in theater, that’s only reason I need to record video on blue ray.
    I have got toast on my mac and it seems very easy, but I need advice what format I should write from final cut pro. So little advice here please
