Activity › Forums › Apple Final Cut Pro Legacy › blue markers fail to convert to edit points in multiclip
  • blue markers fail to convert to edit points in multiclip
    Posted by Nancy Zucchino on February 26, 2009 at 4:39 pm
    I am using the multiclip/cam keyboard layout to cut between angles. I tried using the number pad to choose the angle. The blue markers appear in the timeline each time I choose a new angle.
    However, when I hit the space bar, the blue markers fail to become edit points. The blue markers disappear and there are no edit points.
    But if I use the multiclip button bar, the blue markers I create DO convert into edit points.
    Its just that using the number pad is much more efficient–if it would work. Any thoughts?
    Brad Mitchell replied 16 years, 11 months ago 4 Members · 4 Replies
  • Tom Wolsky
    February 26, 2009 at 5:41 pm
    Could you describe exactly how you activate the keypad, and what you’re doing to use it? Have you tried trashing your preferences?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Christian Hart
    August 24, 2009 at 8:25 pm
    I am having this same problem…
    Really frustrating to get to the end and all your markers just go POOF!
    I am also using keyboard to select angles.
    Will try with button bar (yuk – i might have to get my mouse out!)
    FCP 6.06 / OSX 10.5.7
  • Christian Hart
    August 24, 2009 at 8:38 pm
    hmmm… looks like the keyboard technique with standard controls only switches view – turns out you have to map some extra functions to get it to cut at the same time… There’s no Cut between angles keyboard assignment by default.
    Solution is to map the kepad to Cut between angles and save that layout as a new Multiclip Keypad Setting
  • Brad Mitchell
    October 27, 2009 at 5:06 am
    I’m having the same problem with blue markers, but I am unable to get custom key commands to work with multiclip editing.
    I assign number keys 1 & 2 to cut between angles 1 & 2 (2 camera clips only) but when I press either key while the multiclip is running, I get the apple ‘error’ sound and the blue markers appear, but vanish when I hit stop and no edits appear.
    It works ok with the mouse but what am I missing?
    I’ve tried trashing preferences and starting new sequences but no luck.
    Any suggestions?
    Brad
