Activity Forums VEGAS Pro Blue line on Audio track
  • Blue line on Audio track
    Posted by Rick Hughes on November 18, 2013 at 5:52 pm
    When I open one project I see a horizontal blue line between the L&R stereo tracks …
    # What is this ? what does it do?
    # Have I turned something on by accident
    # How do I (& should I ) remove it.
    Just not seen it before.
    Rick Hughes replied 12 years, 10 months ago 4 Members · 5 Replies
  • Graham Bernard
    November 18, 2013 at 6:56 pm
    It’s an Audio Envelope.
    Grazie
  • Roger Bansemer
    November 18, 2013 at 8:20 pm
    You must have hit Shift V to insert it.
    YOu can double click it to add points to the line and then grab the point and raise or lower the volume. Or grab the blue line between two points to raise or lower an area. There are many variations to that.
    Shift P will add a red line which is used the same way but for panning audio.
    Roger Bansemer – PaintingAndTravel.com
  • Rick Hughes
    November 19, 2013 at 9:48 am
    OK … obviously a kybd error on my behalf … can I remove it ?
  • Francis S. dobos
    November 19, 2013 at 6:20 pm
    Yes, you can. Press Shift V again. That’s all.
    Francis S. Dobos
  • Rick Hughes
    November 19, 2013 at 6:38 pm
    Thanks guys … never had call to use this, so foxed me.
