Activity Forums Adobe Premiere Pro Blue flicker on final output when changing clip speed
  • Blue flicker on final output when changing clip speed
    Posted by Karl Lim on March 3, 2011 at 7:18 pm
    hi
    i’ve been having problems these past few weeks regarding changing the speed of a clip in premiere pro.. ok, first of all the clip was exported from after effects in quicktime animation..when i import it to premiere pro and change its speed, it plays with no problems but when it is exported, it has this blue flickering thing in it..a friend suggested that i use time remap instead of changing the clip speed in speed/duration tool but it didn’t fix the problem..does this have something to do with the codec? please help me on this..
    by the way, here’s my system specs..
    intel core2quad q8400 @2.66Ghz
    4GB ram (dual channel)
    nvidia gtx460 1024MB
    500GB seagate SATA HDD
    windows 7 ultimate x64
    adobe premiere pro cs5
    adobe after effects cs5
    thanks in advance!
    Bec Johnston replied 15 years, 3 months ago 2 Members · 1 Reply
  • Bec Johnston
    May 27, 2011 at 11:33 pm
    Hi there
    I have been having the same issues for a while now and I just solved it! It is something that happens during the export and it only happens when you export in Premiere Pro not when you export using Media Encoder. So when it comes up with the option to export or queue, select queue and it will export it in Media Encoder and that should solve the problem.
    Hope this works for you as well.
    -Bec
