Blu-Ray
I’m trying to import from a Blu-Ray player (Phillips BDP 7200) via component out to a firewire converter (ProMax DA-MAX+)
I’m using FCP HD 4.5 on a Dual 1GHz PowerPC G4 (mirror door) running Mac OSX 10.4.11.I’ve set the sequence to DVCPRO HD 720p60 (16:9).
The capture preset to DVCPRO HD – 720p60 (16:9) with the digitizer set to DV.
The Device control preset to a copy of Non-Contollable Device using Apple Firewire protocol and DV Time as the time source.When I try to import using Capture Now I get an error message stating – “Attempt to capture video without a video device selected. Please select a device in your capture presets and try again.”
What am I missing?Thanks
