Activity Forums Apple Final Cut Pro Legacy blu-ray workflow (quick question)
  • blu-ray workflow (quick question)
    Posted by Rick Neely on September 2, 2010 at 12:53 pm
    Hey Guys,
    very quick question I think I know the answer for, but wanted to verify- got a client with HDV footage that might want a blu-ray of it. I currently don’t have a blur-ray burner, but do have FCP7. I know you can output an HD sequence via Export>Share to a blu-ray burner.
    My question is a couple years back I read you could make send a high def sequence into compressor, make an HD-DVD encode, and use DVDSP to burn that onto a REGULAR DVD-5 disc (only 50 minutes tops). I’m assuming I cannot do this with BLu-Ray enocoded files, Yes? I would NEED to have a blu-ray burner and burn to a blu-ray disc.
    Can someone take a moment to confirm? Appreciate it thanks.
    Rick
    Eric Pautsch replied 16 years ago 5 Members · 9 Replies
  • 9 Replies
  • Eric Pautsch
    September 2, 2010 at 12:58 pm
    You can definitely put a BDMV folder on a DVD-R. This is called a BD-5. It wont play on all players though.
  • Rick Neely
    September 2, 2010 at 1:25 pm
    Thanks Eric for this quick response,
    One followup, If I go the route of exporting the FCP sequence as a HD QT, and use Toast 9 or 10 to perform the encode & burn, will a regular DVD-Burner and DVD-5 disc still generate Blu-ray content?
    Put more simply, do I need either BLu-ray discs and/or a blu-ray burner?
    Rick
  • Eric Pautsch
    September 2, 2010 at 1:39 pm
    Nope…just a regular DVD disc. Never used Toast or FCP for BD work so I cant be much help there but it is possible.
  • John Pale
    September 2, 2010 at 2:40 pm
    Rick,
    Not trying to be a smart-ass…but if this client is important to you, why not just get a real external Blu Ray burner and make a disc that will definitely play. They are not horrifically expensive anymore. I am sure you will get some use out of it beyond the current job.
  • Rick Neely
    September 2, 2010 at 2:48 pm
    OK JOHN,
    The Gloves are off you Son if a #$%$%^&!!!
    I WILL be getting an external Blu-ray burner very soon. I am just watching my funds for a few more weeks. I’m not yet sure if this customer (not really a client) is in a hurry or not and it’s not a huge job. I just wanted to ask what my options would be if I needed (for this one job) to work around having a bluray burner.
    Your point is valid and it will happen. As long as we’re on the subject, what do you recommend is the best one for the $$$ (few choices would be great)
    rick
  • John Pale
    September 2, 2010 at 3:14 pm
    I was in a similar situation and picked up this
    https://www.lg.com/us/computer-products/optical-media/LG-external-dvd-burner-BE08LU20.jsp
    It has both USB and eSATA connections. I use the eSATA connection because its faster. I’ve had no problems. It lists for $329, but if you shop around you can get it for under $300.
    I’m sure others will have some recommendations.
  • Walter Biscardi
    September 2, 2010 at 3:17 pm
    We use an internal burner from fastmac.com. Have been using it almost four years now.
    I think they have an external model as well.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Chris Tompkins
    September 2, 2010 at 3:29 pm
    Internal Burners cost $110. bucks now.
    Chris Tompkins
    Video Atlanta
  • Eric Pautsch
    September 2, 2010 at 4:41 pm
    I love the LGs. Its a workhorse
