Activity Forums DVD Authoring Blu-Ray Volume with DVDit Pro HD?
  • Blu-Ray Volume with DVDit Pro HD?
    Posted by Bob Fiori on April 8, 2008 at 2:32 pm
    I posted this on the Sonic Forum, but that does not seem to get much activity. So Here is what I need help with.
    I have my first project in this app. It is a 4min 1080i show, nothing fancy. I need to output to SD for approval, and Blu-Ray for client projection. Had no problem with asset import, or simple Still menu with 1 button. Simulate is fine. I burned the SD Ver Fine. When I go to write Volume for Bluray the process seems to go great until it gets to Adding Assets to DB.The progress line gets to the end and I get a Box that says,
    “The disc Burning Process was interrupted, either because of an error or it was canceled”. Can’t seem to get beyond this. I must be missing something. If anyone can point me in the right direction I would greatly appreciate it.
    Bob Fiori
    Croma-Video Inc,
    Collegeville, PA 19426
    Bob Fiori replied 18 years, 5 months ago 2 Members · 2 Replies
  • Max Kovalsky
    April 8, 2008 at 2:36 pm
    Don’t know much about DVDit, but if it’s a strictly burning error, you should build an image to hard-drive and burn with ImgBurn.
    Max
    Blu-ray author/producer
    New York
    Area4.tv
  • Bob Fiori
    April 8, 2008 at 3:57 pm
    Thanks Max. I do think it is a Sonic issue, or my work flow, because I get the same message when I try to create an image file with this app. That is why I hoped to get some feed back from someone with DVDit Pro-HD experience.
    Bob Fiori
    Croma-Video Inc,
