Activity › Forums › DVD Authoring › Blu Ray to SD DVD
  • Blu Ray to SD DVD
    Posted by Dmitriy Dribinskiy on May 3, 2011 at 11:55 am
    Hello,
    Can any one suggest a way to convert blu ray DVD to standard def DVD? I am a wedding videographer and most of my projects are HD. And now in order to provide client with SD DVD I have to spend a lot of time for transcoding, re-editing, etc. Thanks!
    Patrick Morgan replied 15 years, 4 months ago 3 Members · 4 Replies
  • David Resnick
    May 16, 2011 at 10:41 am
    Did you ever get a good answer? I’m looking to do something similar.
  • Patrick Morgan
    May 25, 2011 at 2:23 pm
    what dvd authoring program are you using?
  • Dmitriy Dribinskiy
    May 25, 2011 at 3:02 pm
    encore cs5
  • Patrick Morgan
    May 25, 2011 at 3:08 pm
    All you should have to do is open the encore project go to your build tab then change the format from Blu-ray to DVD and then the output to DVD Disc. This is what I do.
