Activity Forums VEGAS Pro Blu Ray render question for 720-60p video
  • Blu Ray render question for 720-60p video
    Posted by Dave Petteruto on July 16, 2013 at 11:06 pm
    I have a Vegas(10) project with HD video that is 720-60p with project properties of 1280 x 720 59.940fps. To render this for Blu Ray (using DVDA) what would be the best way to go?
    Dave P.
    Intel I7 950, 12GB RAM, NVIDIA GeForce GTX 460 SE, Vegas Pro 10 (32bit/64bit), Windows 7 Pro 64bit, LG WH10LS30 10X Bluray Burner.
    John Rofrano replied 13 years, 2 months ago 2 Members · 3 Replies
  • John Rofrano
    July 18, 2013 at 11:06 am
    Unfortunately, Vegas Pro doesn’t ship with any 60p Blu-ray templates and neither Sony AVC or ManConcept AVC will allow you to set the frame rate to 60p so you are stuck at the moment until Sony adds this support to Vegas Pro.
    One workaround I can think of would be to render to Video for Windows using the HD 720-60p YUV template. Then create a Blu-ray 720-60p project in DVD Architect and give it this file. It should render it to 720-60p for you. I realize this is two steps so maybe someone else has a better solution but that’s one possible workflow.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Petteruto
    July 22, 2013 at 2:43 pm
    Thanks for the info John. I’ve been away on vacation otherwise I would have responded sooner. I will certainly give your method a try. I take it that your suggestion once burned to Bluray disc should play ok in all or most Bluray players?
    Thanks again for the suggestion.
    Dave P.
  • John Rofrano
    July 23, 2013 at 3:05 am
    [Dave Petteruto] “I take it that your suggestion once burned to Bluray disc should play ok in all or most Bluray players?”
    It should. 720-60p is part of the Blu-ray spec.
    ~jr
