Activity Forums VEGAS Pro Blu-ray questions
  • Blu-ray questions
    Posted by Paul Gregory on December 16, 2012 at 11:54 pm
    I have a copy of an older video file that was make up of a about half 1280×720 mov file & the balance of much higher resolution jpeg’s. I would like to put this onto a Blu-ray disk. What template would you recommend? Normally I think its recommended that you don’t re sample upwards.
    As for the template in general I notice they offer 10mbps or 16mbps. Does this mean that you can’t use any bit rate in between?
    The Blu-rays disks I’m told are much less prone to scratching than a DVD because they have a thicker coating. But what about the data on them will it last or is it too soon to know?
    Thanks in advance
    John Rofrano replied 13 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    December 17, 2012 at 11:57 am
    [Paul Gregory] “I have a copy of an older video file that was make up of a about half 1280×720 mov file & the balance of much higher resolution jpeg’s. I would like to put this onto a Blu-ray disk. What template would you recommend? Normally I think its recommended that you don’t re sample upwards.”
    You might have to make your own 720p template. I’m not sure if DVD Architect will then re-encode this. I never shoot 720p so I don’t know. All of my work is at 1080i. I would start with a template like Blu-ray 1920×1080-60i, 25 Mbps video stream and change the Frame size to HD 720 (1280×7820) and the Filed order to None (progressive scan).
    [Paul Gregory] “As for the template in general I notice they offer 10mbps or 16mbps. Does this mean that you can’t use any bit rate in between?”
    You can change it to anything in between by editing the template. In Vegas Pro 12.0 the Blu-ray templates are 10Mbps and 25Mbps.
    [Paul Gregory] “The Blu-rays disks I’m told are much less prone to scratching than a DVD because they have a thicker coating. But what about the data on them will it last or is it too soon to know?”
    Since none of us have a Blu-ray disc older than a few years I’d say it’s too soon to know.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
