Activity › Forums › Adobe Premiere Pro › Blu-Ray on normal DVDs
  • Blu-Ray on normal DVDs
    Posted by Brian Paterson on April 29, 2012 at 1:32 pm
    Hi, I make wedding videos and have had my first request for the finished film to be Blu-Ray. I don’t possess a blu-ray burner and as I am closing my business and this will be my last job I do not want to spend a lot of money on hardware I will never use again. I recently saw an article that said I can burn HD video to a normal DVD using toast with their Blu-ray disc plug in. Does anyone know anything about this.
    The footage is : Ex1 xdcam, shot- HQ 1920/50i, edited in FCP7, pro-res timeline. My computer is an iMac and I burn my DVDs using a sony external DVD writer.
    Will it work as easily as the manufactures suggest and what quality could I expect. Everything seems to have it’s pitfalls and I wondered what they would be in this case. Any thoughts, advice or insight as to the working process on this would be much appreciated. Regards BRIAN
    brian paterson
    Brian Paterson replied 14 years, 5 months ago 3 Members · 5 Replies
  • Ron Pestes
    April 29, 2012 at 4:04 pm
    Yes, I have done this but you only get about 20 minutes on a regular dvd. I use Toast as well.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    Adobe CS6 Production Premium
  • Brian Paterson
    April 29, 2012 at 5:31 pm
    Thanks Ron, according to articles I have read you can get up to an hour but can retain best quality up tp 40 minutes. Is this not correct.? Do I have to output from FCP as a blu-ray file or will toast convert it from my normal file. ( Normally I output a reference file and make a disc image using iDVD, which I then use to burn the DVD using toast.) Can you tell me if the quality is as good as burning to a blu-ray disc using a dedicated burner and finally one last question – when I make a normal DVD from 50i footage I never deinterlace and on a normal television there are no jaggies. However, never having made a disc to be played on a blu-ray player to be shown on a high def television set I don’t know how it will look if I do not deinterlace. Will I see jaggies if i do not or will it be smoothed out in the same way that a normal TV does.
    I would do some tests myself if I had a blue ray player and high def TV but sadly I do not.
    Many Thanks BRIAN
    brian paterson
  • Ann Bens
    April 29, 2012 at 6:38 pm
    Beware this DVD can only be played with a BD-player (computer or standalone) and not all standalone BD players will play this DVD correctly.
    BTW this is the Premiere Pro forum.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Ron Pestes
    April 29, 2012 at 8:23 pm
    According to what I know it will make a progressive disc from your interlaced footage. I let Toast do all the encoding and it seems to be as good a quality as a Bluray disc.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Brian Paterson
    April 29, 2012 at 10:33 pm
    Thanks for all your help and apologies for posting in the wrong forum. OOps!
    brian paterson
