Activity Forums Adobe Encore DVD Blu-ray Object: Export file not found — Solved
  • Blu-ray Object: Export file not found — Solved
    Posted by Neil Sadwelkar on June 17, 2015 at 1:16 pm
    Burning a complex multi menu Blu-ray. 6 timelines and lots of chapters. Took a while to set up links etc.
    Checked project for errors. None found.
    Tried to build a disk and got the error
    Blu-ray Object: “_____”, Export file not found.
    Searched here on the Cow as well as Adobe forum. No good reply.
    Replies like uninstall and re-install Encore. Import media and redo menus and chapters. Or rename media files and reconnect. Tried everything. No luck. Rebuild entire project not an option. Too complex (and boring) to redo.
    I even did a uninstall and re-install of Encore. And got the same error. Even transferred the files and project to another computer and tried. No luck.
    Finally, removed all the .ac3 tracks in all timelines. Reimported the ac3 files. Placed them in timelines. Did a build. And it worked.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
    Per Scaffidi replied 9 years, 6 months ago 2 Members · 1 Reply
  • Per Scaffidi
    March 21, 2017 at 3:51 pm
    I fixed the same issue in Encore 5.5 by simply deleting the offending file from encore and re-importing.
