Activity Forums VEGAS Pro Blu Ray .mpg2 Template
  • Blu Ray .mpg2 Template
    Posted by Sam Caino on December 28, 2012 at 6:58 pm
    Precisely what changes can you make to the Architect Blu Ray .mpg2 template when you render out of Vegas without causing Architect to re-render during the burning process. I have so far successfully lowered the max bit rate without triggering the re-render. I am wondering what other flexibility I have.
    John Rofrano replied 13 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    December 28, 2012 at 11:02 pm
    [Sam Caino] “Precisely what changes can you make to the Architect Blu Ray .mpg2 template when you render out of Vegas without causing Architect to re-render during the burning process. I have so far successfully lowered the max bit rate without triggering the re-render. I am wondering what other flexibility I have.”
    Usually you would only change the average bit rate. There is no need to change the max if using variable bit rate. It’s the average that determines the file size. What other changes can be made and remain compliant is not documented.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
