Activity › Forums › Adobe Encore DVD › Blu Ray menu problem!! (Loop) Encore CS4
  • Blu Ray menu problem!! (Loop) Encore CS4
    Posted by Camila Umaki on August 20, 2013 at 8:46 pm
    First, sorry for bad english..
    I authored a Blu Ray disc on Encore CS4, but the menus won’t work properly! The disc has 2 menus that are very simple, and both have the same problem: the music plays for about ONE second, then black appears, the menu restarts, music plays for a second, black appears again, and it goes on and on… Checked project, and it says it’s all ok.. Via preview the menu works fine too
    PS: the same project recorded on DVD works just fine!
    Both menus are still images, .PSD
    The songs are MP3 format, and about 3 minutes duration
    The settings in the motion panel are as follows:
    Video: Nothing
    Audio: Main Menu Music.mp3
    Duration: 00;03;01;04
    Hold Forever: Greyed out and unchecked
    Animate Buttons: Unchecked
    Loop Point: 00;00;00;00
    Loop #: Forever
    I don’t use override at all
    I’ve burned previous projects to blu-ray on Encore CS4, but with no problems! Started an entirely new project, but the problem persists
    Someone please help!
    Camila Umaki replied 13 years ago 2 Members · 2 Replies
  • Jon Geddes
    September 4, 2013 at 9:51 pm
    Encore CS4 had issues with the rendering of a menu finishing prematurely and not giving any indication a problem had occurred. It only rendered 1 second of menu, which is why it keeps looping 1 second. You can try making a video of the menu which is the same duration as the audio file. Use that instead of the still image for the background. This could resolve the problem.
    Jon Geddes
    http://www.precomposed.com
  • Camila Umaki
    September 6, 2013 at 11:32 pm
    Thank you for answering!
    Do you know why that happens? Is it just another bug? Is there any solution? I’ve burnt the same project on CS6 and it worked perfectly.
