Blu-ray image rendering problem
Posted by Larry Brewer on October 21, 2008 at 8:54 amIs there a reason that I can’t change the Image parameter-File path in the “Burn Blu-Ray disk” options window? I plan to render image only and can’t seem to assign a folder and file name to the project. I click browse in the image parameters section of the Burn Blu-ray disk window, select new folder and file name, click OK and it comes back unchanged with the previous folder file name unchanged. What’s the deal?
Larry Brewer replied 17 years, 11 months ago 2 Members · 5 Replies -
John Rofrano
October 21, 2008 at 11:39 amWorks for me. Try typing the path in manually although it really should work as you described. Maybe there isn’t enough space in the location you pointed to? (a 25GB Blu-ray project may need 50GB+ to prepare) I’m just guessing here because it works for me.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Larry Brewer
October 21, 2008 at 12:04 pmJohn, thanks for the reply. I’m baffeled. It isn’t the file size or lack of space. I have 2 computers side by side and the same resluts on both. Just tired again with a 1 minute selection loop region, very small file size. No luck. here’s the step by step precedure I’m using.
1. place clip to be burned to bluray on timeline.
2. select entire clip by placing all in Loop region (84 mins.)
3. tools/burn disk/blu-ray disk/
4. OPERATION – render image only
5. RENDER PARAMETERS – Sony AVC, Blu-Ray 1920×1080-60i, AC-3, render loop region only
6. IMAGE PARAMETERS – FILE PATH – click browse, create new folder on drive other than media drive, type file name, click save…At this point the file path remains unchanged from the path I tried to change,
I get the same results on both computers. Both are running 8.0c, quad intel CPU.
Both computers function as expected when I render files such as wmv, or mpg2 files. No problem assigning folders and file names. This is strange. What am I doing wrong?
thanks as always for your interest and help.
Larry Brewer
Larry Brewer
October 21, 2008 at 12:08 pmJohn, thanks for the reply. I’m baffeled. It isn’t the file size or lack of space. I have 2 computers side by side and the same results on both. Just tired again with a 1 minute selection loop region, very small file size. No luck. here’s the step by step precedure I’m using.
I have no problem rendering files to folders I select and files names I type in. Only in the Blu_ray disk burning do I see the issue.
Larry Brewer
John Rofrano
October 21, 2008 at 12:20 pmOK, my bad. When you said Blu-ray I automatically assumed you were using DVD Architect. (sorry). I followed your steps and got the same problem. Looks like a definite bug in Vegas 8.0c. I would report it to Sony.
~jr
Larry Brewer
October 21, 2008 at 1:07 pmJohn,
Thanks for following up. Same problem with 8.1 I’ve confirmed. In the meantime, I’ll just use the folder I’m stuck with then move and rename the files after the rendering.
One other detail. My edit4 computer uses the default folder in the C drive/User/Vegas/Pro/… My edit2 computer uses a folder and file name from a previous render on another project. Neither can be changed. How weird is that?
Larry Brewer
