Activity Forums Apple Final Cut Pro Legacy Blu-ray footage.
  • Blu-ray footage.
    Posted by David Ethridge on April 30, 2009 at 1:48 am
    I have some clips that are 1080i60 from my HVR-z7u and if I add color correction to the clips on the timeline I notice that later on my Blu-Ray DVD after exporting it from FCP to Mpeg2 streaming in compressor most of my clips look great but some of them are pixelated. Looks great in FCP.
    Im wondering if I need to render my clip before exporting to compressor to fix this?
    I did> FCP 1080i60 using apple prores422 >Compressor Mpeg2 streaming codec for blu-ray>Encore build.
    Walter Biscardi replied 17 years, 4 months ago 3 Members · 2 Replies
  • Rafael Amador
    April 30, 2009 at 9:09 am
    [David Ethridge] “Im wondering if I need to render my clip before exporting to compressor to fix this? “
    No necessary. Compressor renders everything, even if have been prevoiously rendered.
    I suggest you something: In your Sequence Setting, set “Render all YUV material in High Precission”.
    This will make that your 8b HDV footage will be rendered as 10b footage.
    Rendering will take longer.
    You can try to export a Self-Contained movie and import that to Compresssor.
    The problem of sending from FC to Compressor is that, as we say before, it renders everything again.
    If yu are doing a Double-pass compression render everything twice.
    Rafael
    http://www.nagavideo.com
  • Walter Biscardi
    April 30, 2009 at 9:17 am
    You probably need to turn up the bit rate in Compressor.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
