Activity Forums Adobe Encore DVD Blu-ray Error: “fatal error”, Code: “6”, note: “video buffer underflows. Total bitrate is too high near time = 7.048700 seconds –
  • Blu-ray Error: “fatal error”, Code: “6”, note: “video buffer underflows. Total bitrate is too high near time = 7.048700 seconds –
    Posted by Richard Acosta on September 6, 2012 at 9:00 pm
    I have been using Adobe Encore CS5 on a mac for some years now and have never had this issue, I was hoping someone might have found a solution for this. I encountered the following error message during a Blu Ray authoring project:
    the project was exported from within adobe premiere using the H.264 preset for Blu-ray.
    The menu’s were custom made in photoshop using the proper codes for buttons/chapters/video etc.
    when the project was complete and I “checked” the project, no issues come up. when I start the “Build” the program begins by processing the menus and this takes quite a while and it reaches up to my last submenu and the error message pops up. the discs I’ve used go to waste and the project is still not delivered. Help?
    I’ve authored multiple times before, I’m not sure if I changed something in the process that might be causing this error.
    Sam De clercq replied 8 years, 6 months ago 6 Members · 10 Replies
  • 10 Replies
  • Stan Jones
    September 6, 2012 at 11:03 pm
    Are these motion menus? I’d look at the transcode settings for those. Remember that total bitrate includes audio.
    If it is not the menus, then same issue re timeline. But at 7 seconds?
    Stan Jones
  • Richard Acosta
    September 7, 2012 at 4:52 am
    Hi Stan, Thanks for the inquiry, it’s actually a basic photoshop file that i converted as a menu, however, I did drop an audio file to the menus for background music, otherwise the menu and two submenus are all pretty basic. The transcode settings for the project are the default settings for BluRay in encore:
    Codec:H.264
    Dimensions:1920×1080
    Frame rate: 23.976
    Fileds: No fields (Progressive scan)
    Audio Transcoding scheme: Dolby Digital
    Maximum audio/video Bitrate: 15.0 Mbps
    How do you check the transcode settings for the menus? I right clicked on the menu line in the project panel, but the “transcode settings and transcode now options of the menu are greyed out. ?
  • Richard Acosta
    September 7, 2012 at 1:59 pm
    ok, I spent all night re-rendering the file from scratch and redoing the entire project in encore also from scratch changing a few things I thought might help:
    I eliminated the motion menus by eliminating the music file altogether in each of the menus.
    I eliminated several chapters from my timeline to limit the amount of buttons in each menu page
    I eliminated the custom menus and went with a template thinking that perhaps I entered a code incorrectly in my custom menus. and I went from one menu and three sub menus to one menu and two submenus, in other words went as basic as I could possibly go from scratch.
    The transcode settings for the project are the default settings for BluRay in premiere pro to Encore
    Codec:H.264
    Frame rate: 23.976
    Sadly, I went thru another 4 attempts throughout the night and still received the same exact error message each time:
    the bitrate remained unchanged in the message. I’m truly at a loss. any suggestions?
  • Richard Acosta
    September 10, 2012 at 8:58 pm
    Update: Just wanted to link this to another thread that solved this issue:
    https://forums.creativecow.net/readpost/145/871543
  • David Bangura vidéaste
    October 5, 2012 at 2:52 am
    I fought three days with this fatal error code 6 !! I read all the things i found on many differents forums around the net.
    I was desperate! And that night, i decided something new… all the files in my bluray project were H264 – 1920×1080 25p, on my mac osx Lion 10.7.2.
    I selected all my files (movie and menus files) and ask Adobe Encore to re-encode them in MPEG2 BLuray… i woke up at 4 am, just to check, and surprise! My project is finalized, written… It worked!!
    I just have to burn it and deliver it to my client.
    It seems the problem came from H264 files. Can’t explain why it worked, but if you’re upset to loose so much time by trying but not succeding, give a try at my attempt.
    Cheers
  • Richard Acosta
    October 11, 2012 at 11:49 pm
    Hi David, Thanks for the reply, It is in fact because of the H264 files, turns out that older bluray players can’t recognize the H264 codec, they became available and should work if your bluray is relatively new. the older blurays only read the mpeg2 bluray option that encore provides. as with everything else, we learn as we go! I must have burnt about a dozen discs for that one project before I was able to correct all the issues. Thanks for the feedback!
  • Elan Baron
    April 20, 2013 at 4:40 pm
    Hi Richard,
    Can you please post a solution to fix the Encore message one receives (that is, “fatal error”, Code: “6”, Note: “Video buffer underflows. Total bitrate is too high near time”
  • Richard Acosta
    May 15, 2013 at 3:44 pm
    Hi Elan,
    Apologies for the late reply but for this issue, check this link for the resolution to my issue.
  • Alex Martinez
    September 22, 2013 at 2:09 pm
    Sorry to bother but the link is dead, can you please post the solution for this issue again?
    Thank you.
  • Sam De clercq
    February 24, 2018 at 3:31 am
    Same here folks
    Richard posted that link in a previous. thx.
    I passed error 6 after a week trying now and then.
    My last steps were transfering all footage with CBR between 18 – 25 (deppending on the M4V file size).
    imported that M4V into Encore and did copy my transfer-settings from Premiere.
    First i tried wat was suchested before, (MPEG-bluray codec) and that did worked indeed.
    After that I did try like it should have to be wiht H.264-bluray, and which gave us all errorcode6.
    Now it doesn’t pop-up anymore.
    Looks like all systems do have to get used to it when transfering it with a H.264 setting and ones it does pass the process it can remember how to deal with it.
    PS. i did the first encore to BDR transfer on a BR-E with the lowest burningspeed.
    this link is when i NOT saw passing by errorcode6 and the building/mounting did continue
    https://youtu.be/1D6SYqNT2CA
