Activity › Forums › Adobe Encore DVD › Blu-ray Error: Bit Rate too High?
  • Blu-ray Error: Bit Rate too High?
    Posted by Jason Boone on January 20, 2013 at 9:37 pm
    So I get this error every time I try to encode my Blu-ray disc. I am assuming that the bit rate I used to encode from Premiere was too high. Am I correct? If so, does this mean that I need to re-encode all of my assets at a lower bit rate before bringing them into Encore? Or is it some other issue?
    Thanks for any help.
    Daniel Ludwig replied 13 years, 8 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    January 21, 2013 at 7:35 am
    jepp – bitrite to high!
    what codec did you use? H264 or MPEG2? which bitrate did you use?
    blu-ray could only handle 48MBit/s for all content (audio+video). keep in mind that uncompressed pcm(wav/aif)-audio have 1.5Mbit/s bandwith.
    if you have chosen MPEG2HD, I would advice to use H264, as it could create the same quality as MPEG2 at a lower bitrate.
    cheers
    danny
